tread plate removal
Old Dec 7, 2023 | 05:41 PM
  #21
specops1526's Avatar
FYI, if you need those plastic grommets that go under the tread plates for the screws, you can get them at your local hardware store that carries parts from Hillman Group. I had my hardware store order a small box for me.
Product number is 45989-H, Item #400169
Comes in a box of 20
Here's a prior thread about it: https://landroverforums.com/forum/di...iece-id-95112/
Old Dec 7, 2023 | 05:44 PM
  #22
mackendw's Avatar
I scarfed 12 of them at the local U-pick in Largo. thx. they came out pretty clean...I thought they would be brittle and break. will bookmark that link though. thx.
Old Dec 8, 2023 | 11:16 AM
  #23
mackendw's Avatar
Here is where I'm at re: fixing the floor rot in my disco:
Old Dec 8, 2023 | 12:10 PM
  #24
mackendw's Avatar
new panel welded in....now onto the door lip for the gasket...plan is grind the old piece off and weld a new one on ....should be solid now.
Old Dec 8, 2023 | 03:12 PM
  #25
mackendw's Avatar
finished up the trim piece for the door gasket to rest on. seam sealed everything...one little corner transition from the horizontal run to the vertical for the door gasket trim.
here she is:
Old Dec 8, 2023 | 05:51 PM
  #26
mackendw's Avatar
and I do have the rubber cover for that access hole for removing the chassis bolt. another score at the U-pick....
Old Dec 9, 2023 | 01:24 PM
  #27
mackendw's Avatar
got her all done. just have to let the final coat of paint dry good before installing the carpet (which I had to remove a ton of rust stains from it). then the seat gets rebolted.
here it it today:
Old Dec 9, 2023 | 03:43 PM
  #28
mackendw's Avatar
2 days to do this....1st time ever did a floor. not a perfect job...but it's a 20 yr old rig. get me by for another long while.
btw...I put a new door seal in and closing the door now is VERY hard. do you have to adjust the striker plate when you put new door seals in?
Old Dec 11, 2023 | 09:37 AM
  #29
Windycity_rover's Avatar
not sure about the striker plate but you can adjust the window frame. Remove the door panel and loosen the bolts at the bottom. This allows the window frame to tilt. I had to do this to get rid of some wind noise. I have been following this post as I have some floor rot in the same area. Great job!
Old Dec 31, 2023 | 08:06 AM
  #30
Xanthro's Avatar
Originally Posted by Best4x4
Still one of my favorite mods = installing RRC aluminum plates vs the stock D2 plastic ones. Had to cut on them a little, but no more brittle plastic!!! I have a set on my 95 D1 and 02 Kalahari. Sadly very $$$ if you buy them online & hard to find unless a RRC shows up at a junk yard near you.
Great idea. I had to get mine out of the UK on Ebay, but will be delivered in early January. (I ordered in early December.)
Tee67
LR4
Jun 4, 2023 10:17 AM
sweet51376
LR2
Nov 3, 2014 08:09 PM
wastesandpines
Feb 27, 2014 11:05 PM
Grlica
Oct 28, 2010 07:30 PM
