Trim Fix/Removal
Old Dec 31, 2014 | 09:17 AM
wild driver's Avatar
Default Trim Fix/Removal
I have a '99 that I need to replace the black exterior trim piece just behind the driver's side rear door. I assume I have to pop out the round plastic "plug", screw cover, or whatever it is on the inside that holds the big plastic interior trim that extends all the way back to the rear door. I don't want to break something taking it apart so what I am asking is, is it safe just to pop out that round plastic plug and pull the interior trim back far enough to swap out the nuts on the exterior trim piece? Or is there a better, or certain way it needs to be done? Thanks in advance.
Old Dec 31, 2014 | 09:29 AM
coors's Avatar
I'm not sure I follow, can you post a pic of where you are referring too?
or maybe this work as a point of reference?
Old Dec 31, 2014 | 10:01 AM
Sure,
The two inch wide piece of black plastic trim right behind the rear door. The piece between the door jamb and the painted part of the body between the rear door and the rear side window. If you go up the joint of the rear door just above the rear wheel it ends at the piece of trim I am talking about. Thanks
Old Dec 31, 2014 | 10:46 AM
Alex_M's Avatar
If you'Re talking about the piece I think you're talking about, then you have to remove the bolts from the inside. You will need to remove the large tan trim piece that goes around the rear side window in the back. I think there are three bolts, or maybe just nuts. Pretty simple job to do, just be careful not to break stuff. I learned that the hard way...
Old Dec 31, 2014 | 11:06 AM
Yes, that is what I am talking about. On the large tan plastic interior piece...do I just pop out the round plastic plugs? is that what holds it on? Or are they just covers for screws? I don't want to learn the hard way. Thanks.
Old Dec 31, 2014 | 11:11 AM
abran's Avatar
My wife is 99% sure the three nuts holding the exterior trim are 7mm, I said they were 8mm.
I believe one of the tan tabs is a cover for a screw, near the rear pillar. It looks different than the rest, the others just pull out with panel popper tool.
Old Jan 2, 2015 | 03:47 AM
OffroadFrance's Avatar
Just smile and agree abran you know what happens and the ensuing tantrums if you disagree with them and it's only 1mm after all.
Old Jan 2, 2015 | 03:51 AM
abran's Avatar
Funny! 1mm can make a difference
Problem is, she is probably right! That item is her job when we part out a car...
xhevi
Jan 17, 2019 01:31 PM
FreeRideSLR
Jun 24, 2014 07:17 PM
lsmit605
May 11, 2011 11:50 AM
BSundownerC23
Feb 28, 2010 11:24 PM
sinebubble
Dec 11, 2009 02:07 AM
