trouble lights are on! ABS, TC, hill decent, check engine...
Old Dec 17, 2010 | 02:38 PM
drakenkade's Avatar
6th Gear
Default trouble lights are on! ABS, TC, hill decent, check engine...
First time owner...
Help!!!
I bought this LR and the ABS doesn't work. When I test drove it I hammered the brakes and I thought they worked but when I tried them in the snow they didn't work and neither did the TC. What should I do? There are no LR dealerships within a 2 hr drive.
Thanks
Old Dec 17, 2010 | 02:56 PM
jbarr89's Avatar
http://www.landroverclubvi.com/abs-mod.html
this is an option, I personally have not done this but plan to to fix my ABS error, check out his other links too.
these are know as the "three amigos", do a search with that term and you'll get a plethora of info
Old Dec 17, 2010 | 03:14 PM
texmbr's Avatar
Do a google search for a local rover group in your area. Someone might have a Amigo reader and be able to see what your codes are. Short of that I did the option B repair that you will find in that link last weekend on my wifes Disco and so far...no lights. But I had ruled out that it was a sensor and was in the modulator.
Old Dec 17, 2010 | 03:39 PM
hilltoppersx's Avatar
you need to read the codes before going after the modulator. it could be a million things. get you CEL read as well it may be a 1590 which will go away once the ABS issue is taken care of but could be unrelated.
Old Dec 17, 2010 | 03:51 PM
oysterhead's Avatar
read the codes. dont just start replacing/fixing things. probably shuttle valve but you never know. could be squeaky brakes. or 100 other things.
Old Dec 19, 2010 | 01:28 AM
drakenkade's Avatar
6th Gear
Default Thanks!
I'll try and find someone locally to read the codes and I'll let you all know what the results are.
Thanks
kev c
Freelander
Aug 4, 2008 06:06 PM
dsmtrain
Jul 12, 2008 07:15 AM
02DiscSD
Sep 11, 2007 12:24 PM
shagybruce
Sep 7, 2007 05:07 PM
dgd
May 16, 2005 03:58 PM
