Tune-Up and Coolant Leak
Old Feb 13, 2012 | 05:25 PM
borchera's Avatar
Originally Posted by BillyAMoody
Almost got it back together.
There's a plastic hose (I think it's emissions or vacuum) adjacent to the rear of the passenger valve cover.
I didn't unhook it from anything, but it's disconnected. Looking at the Rave I think it might be a snorkle tube or something similiar, but I'm not sure.
There's a couple back there but they're all conneced to something. This one just comes up from along the firewall and loops over about 2 inches.
Any ideas?
thanks,
Billy
This is your breather tube for the either the transfer case or transmission.
2003 Discovery 125 K with high miles complete
Old Feb 14, 2012 | 08:10 AM
BillyAMoody's Avatar
6th Gear
Pretty much got'r done. I need to replace the intake coolant hose and clamp, it's dripping a little, and I busted the throttle body coolant hose. The hose and clamps are holding but I'm gonna replace it anyway. I'll say it's pretty freakin' amazing how much more responsive it is. Gotta be the Magnecor wires.
Old Feb 14, 2012 | 08:11 AM
6th Gear
thanks again for the help. I learned a little this time. She ain't 350, but I'll get'r sorted out.
Old Dec 29, 2014 | 03:10 PM
sdhow's Avatar
Default RTV around water ports?
Originally Posted by 4x4trouble
use gasket sealant around water ports
RAVE does NOT call for this; is it advisable???
Old Dec 29, 2014 | 03:27 PM
abran's Avatar
I use a specific for thermostats sealent
Old Dec 29, 2014 | 03:44 PM
sdhow's Avatar
No, not the TYPE of RTV...should RTV be applied around the four water ports?
Does using a steel rather than composite valley pan gasket make a difference?
Old Dec 29, 2014 | 07:12 PM
Kenso's Avatar
I would, I did mine per the RAVE the first time with no RTV and had a slight leak (using an OEM gasket), had to redo it which was no fun at all considering I was just in there. Actually, I got completely pissed off and RTV'd the world pretty much after that, but no leaks and runs perfect so I'm ok with deviating from the RAVE on this one.
Do yourself a favor and change out the injector O-rings while it's apart too.
Old Dec 29, 2014 | 08:30 PM
sdhow's Avatar
Did you use RTV on BOTH sides of the valley pan gasket (head AND intake manifold sides)?
I'm using a Payen plated steel gasket this time; will that make any difference?
Old Dec 29, 2014 | 11:17 PM
Kenso's Avatar
I did apply it to both sides.
I would RTV it regardless of which gasket you use, better safe than sorry in my book. It definitely won't hurt anything.
Old Jan 8, 2015 | 12:06 PM
hinton5408's Avatar
Default unknown coolant leak
I have a 2003 discovery 2 that I recently had the upper radiator hose assembly blow. I have repaired it but when I have the car running, coolant is still spilling out the bottom. The temp gauge in the car stays cool but the red hot light is still on. My thoughts are that the water pump is pumping the coolant but maybe the hose is off on the end of the pump.
Anybody else have any experience with this? Where should I look first?
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
