Turn on the Heat and the A/c blows cold?
Old Jul 1, 2010 | 03:21 PM
Sigma3's Avatar
7th Gear
Default Turn on the Heat and the A/c blows cold?
2002 disco. I was attempting to bleed the air out of my system (dreaded water fall sound in dash) and went to turn on the heat, and the ac comp kick on? Any ideas?
TIA
Old Jul 1, 2010 | 07:24 PM
lordmorpheus's Avatar
Have the defrost on?
Old Jul 1, 2010 | 08:34 PM
No worries mate, the heater will still work with the a/c on.
But try turning it to ECO (economy) mode on the HVAC system.
Old Jul 1, 2010 | 09:40 PM
Sigma3's Avatar
7th Gear
Thats just it even on economy it still blows cold. I let it sit for a while at operating temp, still no heat. my thermostat broke a while back and I recently blew off the coolant hose at the radiator. When refllling the system I had the bleeder scre open and I noticed alot of bubbles in the collant res.
Old Jul 1, 2010 | 09:45 PM
Remove the coolant reservoir and with the bleed screw loose raise it as far as you can.
Then just keep the heater on hot and rev the engine to 2,000 rpm and hold it there for 5-10 min and have a friend keeping a eye on the reservoir to make sure it stays full.
Leave the cap off while doing this and the bleed screw loose, once air stops coming out of the bleed screw close it, let the engine return to idle and see if you have heat.
Old Jul 1, 2010 | 10:40 PM
vandev's Avatar
Default least of your problems..
You can top dollar for your truck here in florida.....i havent turned on the heat in about 8 years ..well that is to see if it actually worked....Sounds like a kool dream truck....
Old Jul 2, 2010 | 12:09 AM
Spencerfitch's Avatar
sure its not bypassed by previous owner?
Old Jul 2, 2010 | 07:21 PM
Is the thermostat on the right way?
If it is on wrong you wont get heat.
2001_Disco
Dec 10, 2014 01:36 PM
rtsixty
Dec 9, 2013 11:00 AM
VikingDiesel
May 22, 2009 07:34 PM
VikingDiesel
Feb 23, 2009 09:01 PM
Brad S1
Jul 5, 2008 04:54 PM
