Turn off Service Engine Light
Old Sep 21, 2006 | 03:29 PM
elanghout's Avatar
3rd Gear
Default Turn off Service Engine Light
The Service Engine Light on my 1998 Land Rover Discovery II came on at around 82,000 miles. I was told that is comes on around this time automatically for the oxygen sensor. I replaced the oxygen sensor, but do not know how to turn off the light. Does anyone know how I can turn off the light without having to take it to a Dealer and spend $90?
Old Sep 21, 2006 | 04:02 PM
geoman's Avatar
Default RE: Turn off Service Engine Light
Some of the larger auto parts store chains (Like Autozone, Pep Boys, etc.) have a service for free, or for a nominal charge, where they will hook up a scanner for engine related codes, and then can clear it for you. But this is only for engine management related codes. Their scanners cannot read suspension or body electric component codes.
Please read my tech info pages at www.eurotekapg.com for tips and things to be aware of regarding your Land Rover
Regards,
Geoman
Old Sep 21, 2006 | 06:17 PM
When the check engine light comes on it is for a fault code. If yourO2's needed to be changed, and at your mileage they are just about ready, you replace all 4 of them, not just one. The replacing of one is usually is one fails with low mileage on it, other wise you will have an imbalance of performance between engine banks. As has been mentioned some stores will clear codes for customers, some store however will not have a scanner that can do that function.
Mike
Old Sep 27, 2006 | 03:37 AM
A03's Avatar
A03
Out of Curiousity, how much do they run for? B/c I need to get them done as well..
Old Sep 27, 2006 | 08:57 AM
The best prices right now that I am aware of are at Atlantic British where they are on sale or Rover Connection.
Mike
kcferna
Jul 7, 2009 08:33 AM
Dan_da_LR3_H2_man
May 28, 2009 11:37 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
bavarian_range89
Nov 1, 2007 08:33 PM
elanghout
Sep 23, 2006 10:42 AM
