Turn Signal (Indicators) Issues
Old Oct 8, 2018 | 07:54 PM
Roverdiscov2's Avatar
Originally Posted by Derek Gjessing
Did this ever get fixed? I am having the EXACT same problem
i have the same problem too !! What’s the problem !??
thank you !
Old Jan 27, 2019 | 02:33 PM
JerryJ's Avatar
6th Gear
Did anyone find a solution to this problem?
I have the exact problem.
Old Jan 27, 2019 | 05:40 PM
Extinct's Avatar
I had this exact problem. Turned out to be multiple failed bulbs.Be sure to check all of them, front and rear until they are all working.
Old Jan 28, 2019 | 09:12 AM
NewToTheTwo's Avatar
To add to this - and potentially unrelated but worth checking.
Apparently its not uncommon for the bulb socket to corrode - the contacts in one of mine was heavily corroded to the point the bottom contact actually fell out.
I had none of these symptoms but if you're digging in, you might as well check this too.
Sockets are on Amazon for about $5 each
Old Jan 29, 2019 | 03:08 AM
Derek Gjessing's Avatar
yup! The solution to my problem was corroded header joints under the dashboard. U need the rave manual to figure out What header it is. I cut the corroded wires and soldered them together. Worked like a charm.
Old Jan 29, 2019 | 12:19 PM
Jakerover's Avatar
check your fuse box or pigtail, i had this melted the XYZ pigtail.
Charlie Black
Apr 2, 2018 04:47 PM
alpinacsi
Feb 7, 2018 08:45 PM
jussnb
Aug 13, 2013 09:19 PM
4x4lover
Mar 16, 2013 08:38 PM
starcraft
Jul 6, 2011 07:58 AM
