Turn signal works one way
Old Jun 9, 2013 | 10:05 AM
silar's Avatar
Default Turn signal works one way
On my D2, when I use the turn signal when turning left and return the steering wheel back to center, the turn signal turns off like it's supposed to.
When turning right though and returning the steering wheel back to center, it doesn't, and I have to manually use the turn signal arm to turn it off.
I've not taken it apart yet to look, but I'm guessing it's in the control switch assembly the arm goes into, or could it be something on the steering wheel column that's broke?
Old Jun 9, 2013 | 11:25 AM
It will most likely be the stalk switch, you can get one from a dismantler like Paul Grant. Turn wheel 90 degrees to get at it.
Old Jun 9, 2013 | 12:43 PM
I agree, and Paul is a good person to buy one from.
Old Jun 10, 2013 | 07:57 AM
Bob Loblaw's Avatar
Have you considered just turning left?
Old Jun 10, 2013 | 01:02 PM
SuperSport's Avatar
On my 1966 Mustang, this used to happen regularly. I don't know if it's the same, but the Mustang had a plastic ring under the steering wheel with tabs on it that would catch the switch on it's return. Those tabs would break off. The ring for the Mustang only costs about $4, so on the Land Rover, it's probably only about $50. That is if it even uses the same thing.
Old Jun 10, 2013 | 02:17 PM
grandkodiak's Avatar
If you're asian you could just leave it on all the time... or if youre a woman youre not even required to use turn signals, just jerk the wheel when the turn off comes up.
Jeffery Chow
Oct 11, 2013 01:35 AM
jussnb
Aug 13, 2013 09:19 PM
drdabbles
Aug 17, 2010 07:37 PM
gsxrgessler
Jan 26, 2008 08:34 PM
95Discovery
Jan 10, 2006 09:41 PM
