Two codes on the Disco; could use some direction.
Old Feb 23, 2024 | 10:24 AM
alw85's Avatar
Default Two codes on the Disco; could use some direction.
Upon the recommendation by several Disco owners I've installed the Ultra-Gauge which is phenomenal. It's reading two codes right now that deal with the evap system and I could use some help figuring them out. The first is a P1451 and the second a P1481; I'm replacing the fuel cap on it tonight when I get home because I noticed it didn't seal too well. What other things should I inspect to verify so I'm not jist changing random parts. Any help is greatly appreciated!!!
Old Feb 23, 2024 | 02:42 PM
Harvlr's Avatar
If your fuel cap wasn’t sealing well, you probably found your problem.
Old Feb 24, 2024 | 07:41 PM
alw85's Avatar
Default Replaced fuel cap
I replaced the fuel cap anda still getting the two codes. Also, there's the smell of it burning rich; I have a purge valve coming in and plan on crawling underneath it tomorrow to check the wiring and solenoids at the charcoal canister on the frame rail.
Old Feb 25, 2024 | 02:01 PM
H20nSnow's Avatar
You will have the codes until they are cleared. Does the UltraGuage allow that?
Old Feb 25, 2024 | 02:35 PM
Harvlr's Avatar
You can clear codes with the Ultragauge.
kristofferzen
Oct 28, 2015 12:21 PM
Buzzwalburg
Apr 13, 2012 05:42 PM
DiscoRover007
Nov 25, 2011 12:08 PM
moomoo
May 31, 2011 09:05 PM
chad420
Jan 13, 2011 01:37 PM
