u-joints
I was reading some previous posts but I couldn't really tell which is a good midrange u-joint. I saw the ones at napa for around 30 each. Then I saw the kind on tom woods for around 20. I do know that I need the greassable u-joints. I was just wondering if anyone has a prefference on which ones to get. I have seen some for 60 buck a pop and I think that those a little on the pricey side. Also where is a good place to get a centering ball kit. I keep seing that everyone has been using the neapco but then everyone says that cheapco's suck. Also are the front and rear u-joints the same size. I was thinking 4 u-joints, centering ball kit, with a new roto-flex and the driveline will be happy. Does this sound right or am I missing something. Please help I only want to do this once without the tranny meeting the driveshaft.
Exactly as well as a Roto Flex from Rover Connection.
Make sure to put a grease fittin in both front and rear shafts slip joint, lube the hell out of them then replace the plus.
Phototone
Apr 24, 2008 05:15 PM
