U-Joints
Old Jan 17, 2009 | 07:59 AM
SDinDS's Avatar
Default U-Joints
Just wondering what's the average life for the u-joints on a Disco 1? I'm at 120k and assuming they've never been replaced (which is probably true given the lack of maintenance on it) I know they won't last forever and just thought maybe it would be good preventative maintenance.
Eric
Old Jan 17, 2009 | 09:16 AM
tomfraser's Avatar
Default RE: U-Joints
i'm at 190k and am pretty sure they are original, will be replacing when it's not below 0 degrees outside
Old Jan 17, 2009 | 09:19 AM
If they are greased twice a year and if you are not doing lots of water crossing, they can last a long time. That being said, they can fail in a heart beat also.
With your mileage, I would replace all of them quickly.
Old Jan 17, 2009 | 12:07 PM
SDinDS's Avatar
Guess you're right... better to do it now than on the side of the road. Since maintenance was never a priority for the PO and since I found water inside the CDL tower then I'll get it done.
Stupid question but how many do I need? I didn't check that out when I was last under it and it's only 5 out there!! Should I replace the flex coupling while I'm at it?
Eric
Phototone
Apr 24, 2008 05:15 PM
shagybruce
Apr 2, 2007 09:51 PM
millejdq
Jan 11, 2007 12:00 PM
dpeek
Sep 4, 2006 11:11 AM
klunkerchuncker
Jan 11, 2006 04:33 PM
