Ugggghhhhh Oil Pump let loose today
Old Dec 6, 2012 | 05:36 PM
jafir's Avatar
Originally Posted by 308nut
is the 4.0 a direct swap with the 4.6 if I have to modify too much I might as well do the Chevy swap
A D2 4.0 is.... a D1 4.0 requires a little work. You'd need to swap front covers, cam gear, of course all the intake and related fuel stuff. Oil pan. The crank sensor mount is different, but it's tack welded on. You can transfer the mount.
All of this is assuming the D2 isn't SAI... if it is, the heads are different.
Old Dec 6, 2012 | 06:21 PM
Same yard has a 2000 D2, but it has been there awhile. They did not list any at their yard in Winston Salem, I did not check further.
Old Dec 6, 2012 | 06:57 PM
308nut's Avatar
Originally Posted by 04duxlr
A Chevy swap? Really? I'm pretty sure this has been discussed before. If there is any kind of inspection in your state, it can't be done. If the engine can be made to physically fit (i.e. drivetrain adapters, accessory mounts, cooling system, exhaust, etc.) integrating the electronics will be very time consuming. A reman block with top-hat liners would make more sense and ultimately cost less.
If you don't relly need the vehicle and have plenty of time, patience and skill and relly want to show that you can make the swap actually work, then go for it. Otherwise, stick with a Rover engine.
yes we have emission testing here but i don't worry about it. I have a dealers license and run everything on dealer tags. Time, I have plenty of. I am undecided, Id like to do it but will weigh all the options first. If I do, i will go with a full GM drive train with the exception of the axles. We'll see will decide over the next few weeks.
in my early 20's I and a couple of friends put a Chevy 427 in a 78 Toyota SR5, we ran military axles and 48 inch super swampers. If any of you are from New Orleans and were around in the mid to late 80's you would have known about The Chevota called Childs Play.
Thanks for all the input
Wade
Phatrowles
Jan 9, 2014 10:36 AM
ngarover
Apr 26, 2012 12:48 AM
kallgrer
Feb 19, 2010 12:01 PM
robot808
Nov 18, 2009 11:10 PM
barranr
Jun 3, 2007 06:36 AM
