Ultra gauge
Old Mar 8, 2013 | 01:41 PM
chavhater's Avatar
From: at the side of the road wondering if I own the only Disco that doesn't like getting dirty
Default Ultra gauge
Hi guys can anybody confirm that a Ultra Gauge, can't be used on a 2003 Td5 diesel Discovery please.
Old Mar 8, 2013 | 02:29 PM
br0keit's Avatar
As long as it is OBDII compliant it will work but gauge availability will vary.
The TD5 is a computer managed diesel so I can only assume that you should get SOME useful information out of it. How much I cant tell you though $60 isn't that much to give it a try. Maybe give them a call and see if they know of people that have tried it on a TD5.
Old Mar 8, 2013 | 03:00 PM
chavhater's Avatar
Thank you brOKeit I've just looked on the Ultra Gauge web site. And no the Land Rover TD5 2.5 Diesel engine is not OBD11 compliment
Old Mar 8, 2013 | 10:09 PM
If you can't plug in an OBDII code reader, like at a parts store, then the Ultra Gauge is not for you.
Old Mar 9, 2013 | 01:06 AM
chavhater's Avatar
Hi Savannah, that's what I don't understand I can plug in a OBD11 scanner, indeed I have a Hawkeye, but according to the Ultra Gauge web site none of the Land Rover 2.5 Diesel engines are OBD11 complient ???. Unless I'm reading it wrong.
Old Mar 9, 2013 | 01:12 AM
I'll bet that the UG web site is in error. Does your Hawkeye show coolant temp?
Old Mar 9, 2013 | 01:26 AM
br0keit's Avatar
The ultragauge website just shows known compatible vehicles then goes to say that ANY OBDII compliant vehicle will work but the gauges that become available can vary significantly.
Old Mar 9, 2013 | 01:42 AM
chavhater's Avatar
I've not tried the Hawkeye to test coolest temp,I bought it for identifying the Three Amigos. I'll download the Hawkeye manual and see how to read the coolest temp.
That's why I was wondering if any members had the Ultra Gauge connected to their Diesels.
Old Mar 9, 2013 | 07:06 AM
Here's the Bearmach application matrix. Look in the column marked "Live Data" for your vehicle. That Hawkeye, or Hawkeye Pro, should be an asset, especially if you are more than a quick wrecker ride to the dealership.
File Type: pdf
Old Mar 9, 2013 | 05:00 PM
We dont have diesel Land Rovers here in the US.
Rover_Hokie
Feb 2, 2014 03:52 PM
Discolife
Nov 23, 2011 07:58 PM
01d2Jeff
Nov 19, 2011 10:52 AM
Spike555
ROAMING WITH FRIENDS
41
Oct 24, 2011 06:26 PM
G Reeves
Oct 23, 2011 07:39 PM
