Ultra gauge question
Old Sep 20, 2015 | 04:57 PM
mose802's Avatar
Default Ultra gauge question
How do you get rid of the annoying low fuel alarm?
Old Sep 20, 2015 | 05:17 PM
cappedup's Avatar
My guess is in the "alarms" menu.
Old Sep 21, 2015 | 12:10 PM
acg's Avatar
acg
There is a section in the menu for entering the alarms settings for the low and high values of each performance data. You will want to set the alarm for low fuel level to zero (or to a value which will work for you).
Old Sep 21, 2015 | 03:46 PM
jdwilks's Avatar
While in there I would go ahead and setup a temperature alarm. Everyone probably has their own value but think mine is set to 215 or something like that. I also have the voltage alarm set to 12.9 low and 15 as high or something close to that
Old Sep 21, 2015 | 04:51 PM
markmontana's Avatar
I think he wants to turn OFF the alarms. The alarms only work if you enter fuel menu each time you add fuel. This can get old at times- so I just went in and turned OFF the fuel alarms.
Old Sep 21, 2015 | 05:22 PM
mose802's Avatar
I figured out how to turn it off.
Thanks
Rover_Hokie
Feb 2, 2014 03:52 PM
sorbet35
May 8, 2012 08:29 PM
kpl1228
Mar 12, 2012 11:01 PM
Spike555
ROAMING WITH FRIENDS
41
Oct 24, 2011 06:26 PM
G Reeves
Oct 23, 2011 07:39 PM
