Ultragauge or ?
Good to know.
My daughters came with a stack of maintance records, all from a LR dealer. Head gaskets were done along with a radiator and lots of other stuff. That was quite a few years ago but on about 25k miles ago.
We bought this during the winter. It was a very cold winter here in PA this year and the heater works very well. We had to turn the heat down because it would get way too hot, even with outside temps in the single digits.
That's good. Your temps should stay around 200 give or take a few degrees... unless you have a 180 thermostat. My '99 usually stays around that. Our '04 is a degree or 2 higher, around 205.
I'm not sure what the "cut-off" line is for too high of a temp, but I've told my wife if it gets above 215-220, then pull over and shut it off.
I'm using a cheapo wifi OBD plugin and "dashcommand".
No idea what I'm not getting that I'd get with an ultra gage but I'm pretty pleased with it.
I can clear codes and monitor temperatures - both real time and over time.
Something around $35 for the hardware, $9.99 for the software.
https://itunes.apple.com/app/dashcom...321293183?mt=8
Super Mini iCar2 Vehicle Wi-Fi OBD-II Code Diagnostic Tool / Clearer - White + Black - Free Shipping - DealExtreme
To get accurate mileage and speed readouts, you'll have to calibrate the UG to your car. There is a write up on how to do it in the UG forum on their main website.
I have yet to calibrate mine. It shows I'm averaging 14 mpg's. In reality I'm around 12 mpg's. If you ever change tire size, it'll have to be re-calibrated.
dcarr1971
09-19-2012 09:08 AM
