Ultragauge or ?
Old Apr 16, 2014 | 02:23 PM
Tracker's Avatar
Good to know.
My daughters came with a stack of maintance records, all from a LR dealer. Head gaskets were done along with a radiator and lots of other stuff. That was quite a few years ago but on about 25k miles ago.
We bought this during the winter. It was a very cold winter here in PA this year and the heater works very well. We had to turn the heat down because it would get way too hot, even with outside temps in the single digits.
Old Apr 21, 2014 | 12:19 PM
Tracker's Avatar
I ordered the ultragauge last week, should be here in the next few days.
I double checked the coolant level and it was a little low, about 2 quarts. Also changed the oil and filter.
Drove it and the needle stayed right in the middle, no more up a little and then back down.
Old Apr 21, 2014 | 01:20 PM
mattmo78's Avatar
That's good. Your temps should stay around 200 give or take a few degrees... unless you have a 180 thermostat. My '99 usually stays around that. Our '04 is a degree or 2 higher, around 205.
I'm not sure what the "cut-off" line is for too high of a temp, but I've told my wife if it gets above 215-220, then pull over and shut it off.
Old Apr 21, 2014 | 02:04 PM
Tracker's Avatar
Got the ultragauge today!
How many gallon fuel tank and how many liters are the motors?
Tracker's Avatar
Ok 4.0 liters.
Old Apr 21, 2014 | 03:26 PM
Fallstaff's Avatar
I'm using a cheapo wifi OBD plugin and "dashcommand".
No idea what I'm not getting that I'd get with an ultra gage but I'm pretty pleased with it.
I can clear codes and monitor temperatures - both real time and over time.
Something around $35 for the hardware, $9.99 for the software.
https://itunes.apple.com/app/dashcom...321293183?mt=8
Super Mini iCar2 Vehicle Wi-Fi OBD-II Code Diagnostic Tool / Clearer - White + Black - Free Shipping - DealExtreme
Old Apr 21, 2014 | 03:29 PM
jamestfl's Avatar
25 gal tank
Old Apr 21, 2014 | 05:04 PM
mattmo78's Avatar
To get accurate mileage and speed readouts, you'll have to calibrate the UG to your car. There is a write up on how to do it in the UG forum on their main website.
I have yet to calibrate mine. It shows I'm averaging 14 mpg's. In reality I'm around 12 mpg's. If you ever change tire size, it'll have to be re-calibrated.
Old Apr 21, 2014 | 07:19 PM
Tracker's Avatar
Thanks for the info guys.
I plugged it in and got it somewhat set up this afternoon.
The bottom left is not the oil pressure is it?
Old Apr 21, 2014 | 07:44 PM
zeroone's Avatar
Ug won't display oil pressure. It's the temperature you want.
dcarr1971
Sep 19, 2012 09:08 AM
anbran
Sep 14, 2012 10:07 AM
Antmen
Sep 12, 2012 11:11 AM
ToddD
Jun 27, 2012 10:30 AM
slanginsanjuan
Mar 9, 2012 03:55 PM
