Ultragauge question
Old Jul 31, 2021 | 06:35 PM
DonRW2007's Avatar
Default Ultragauge question
Hi. I know there are a lot of threads on the Ultragauge here - have done a bit of a search but didn’t see anything relevant to my question…
I’ve tried a number of monitoring devices I’ve seen in the postings, and none have performed well (they’re on my workbench if anyone wants them). I finally bought an Ultragauge. Unfortunately, the two main parameters I want to monitor, coolant temp and battery voltage, don’t display. Coolant temp is a menu selection but doesn’t display. ECM battery voltage doesn’t show up on the menu. I don’t need another tachometer or trip mileage indicator…
Any ideas?
Thanks!
DRW
Old Jul 31, 2021 | 06:50 PM
redwhitekat's Avatar
Any ideas?
Thanks!
DRW
wonder why. What page do you have the coolant display on ,? Make sure it’s on page 1 so you can see it
Old Jul 31, 2021 | 08:32 PM
tnrangerover's Avatar
You can assign each gauge to 1 of 7 pages.
I assigned battery voltage and coolant temp to the top 2/3 of the first page and then smaller underneath, I have rpm and speed. Other than that, I use the 02 sensor readout a few pages down but rarely check through the other parameters if I have no codes.
it takes a little finagling, but it should all be programmable in about 20 minutes or so of fiddling.
Old Jul 31, 2021 | 08:41 PM
DonRW2007's Avatar
Understand. I’m saying I can’t seem to get coolant temp or voltage on any page, in any position…
DRW
Old Jul 31, 2021 | 08:47 PM
DRW
but you can assign other gauges? Can you find coolant temp at all or is it missing? Might need to call ultragauge. It was the first thing I did on mine when I plugged it in.
Old Aug 1, 2021 | 08:04 AM
Sandman614's Avatar
DRW
Are you sure you're ECU is outputting those parameters correctly? My ultra gauge displays both fine.
Old Aug 1, 2021 | 11:55 AM
DonRW2007's Avatar
Well, I restored the defaults, and it started registering coolant temp (actually, nothing would show up in position 1 on any of the gauge pages initially). And I see now that the Ultragauge voltage is essentially battery voltage…
Thanks for comments, all.
DRW
jamestfl
Jul 21, 2021 12:28 PM
greisinb
Sep 23, 2020 10:24 PM
film842
May 10, 2015 08:45 AM
cagusmc
Aug 26, 2012 10:48 AM
sorbet35
May 8, 2012 08:29 PM
