Unwanted Vibration... Help!
Old Feb 12, 2008 | 01:12 PM
rsandmeyer's Avatar
6th Gear
Default Unwanted Vibration... Help!
I recently took my 1999 Disco II in to have the O2 sensors replaced. When I got it back I noticed a slight vibration. It seems to occur when between 1750 and 2250 RPM, but only occurs when accelerating. When coasting or below or above this range it does not vibrate. I can feel the vibration in the steering wheel and can hear a clicking from time to time that seems to be coming from the right hand side just below the passenger floorboard.
I'm sure it is just a coincidence that it happened right after the O2 sensors were replaced, but wanted to include the info just in case.
1999 DII 102K.
Thanks....
Old Feb 12, 2008 | 01:40 PM
Default RE: Unwanted Vibration... Help!
Any check engine light?
Have you replaced you 2 front u-joints in the double cardon, they may be failing.
Old Feb 12, 2008 | 06:02 PM
rsandmeyer's Avatar
6th Gear
No, check engine light is no illuminated. I have not replace the u-joints. What are the tell tale signs that they are going out and how much should I expect to pay to have them replaced?
Old Feb 12, 2008 | 06:34 PM
jkid's Avatar
There usuallyare no good signs except when you're driving down the road and bang, you need a new transmissionplus a newdriveshaft. I think it's about $200 for a transmission shop to replace them.
Old Feb 12, 2008 | 06:47 PM
yarddawg's Avatar
A brand new Land Rover front drive shaft will run you between $400-500. And Land Rover drive shafts don't come with greasable u-joints... you definitely want them greasable (for longevity).
I bought a rebuilt one from an online Rover Parts Dealer for about $150 and had it installed for about $100.
Old Mar 25, 2016 | 11:30 AM
MysteeklRover's Avatar
What site?
Old Mar 25, 2016 | 11:35 AM
abran's Avatar
http://lucky8.com
victormelgoza
Freelander
Jul 12, 2009 10:48 PM
BIG g
Jul 12, 2009 09:32 PM
brianex
Nov 2, 2008 06:16 PM
kaimakliotis
Feb 25, 2008 02:15 PM
pdowning6
Nov 5, 2007 03:57 PM
