Upper Intake
Old Dec 6, 2011 | 07:32 PM
buick215's Avatar
Default Upper Intake
I know that the torque setting for the upper intake manifold is 16 lbs. ft. or 22 Nm but what is the sequence.
Old Dec 6, 2011 | 07:39 PM
drowssap's Avatar
I think you just work your way from the center out
Old Dec 7, 2011 | 06:06 AM
mln01's Avatar
See p.12-2-47 of RAVE, p.202 in my PDF.
Old Dec 7, 2011 | 08:35 AM
drowssap's Avatar
I believe p.12-2-47 of the rave addresses the lower intake not the upper intake
Old Dec 7, 2011 | 09:12 AM
Make sure to use loctite on those bolts cause they do vibrate loose.
Old Dec 7, 2011 | 09:46 AM
buick215's Avatar
Yes, I have heard that they have a tendency to vibrate loose. That is why I was planning on re-torquing them, but now that you mentioned the loctite I might put some on the bolts.
Old Dec 9, 2011 | 07:07 AM
mln01's Avatar
Sorry, my bad. I was thinking lower intake.
RAVE just says "Using a new gasket, position upper inlet manifold. Fit bolts and, working in a diagonal sequence, tighten to 22 Nm (16 lbf.ft)."
Page 30-2-17.
Old Dec 28, 2011 | 08:52 PM
joking41's Avatar
is the upper intake gasket reusable? im replacing the wires because they fell on the header due to the last owner neglect. its a 2000 land rover discovery 2, engine is a ohv
Old Dec 28, 2011 | 10:19 PM
Rovin4life's Avatar
you can pull the hoses off the heater core on the engine side and pull off the wires that way.
Old Dec 28, 2011 | 10:32 PM
boris_gti's Avatar
I heard some people on the forum reuse them (as long as you take it off carefully) but personally, I always buy a new one. I don't feel like getting a headache over a small air leak and crazy codes that might come on later down the road.
