Upper Intake
Old Dec 28, 2011 | 11:01 PM
jafir's Avatar
Originally Posted by boris_gti
I heard some people on the forum reuse them (as long as you take it off carefully) but personally, I always buy a new one. I don't feel like getting a headache over a small air leak and crazy codes that might come on later down the road.
Land Rover parts, spares, Land Rover accessories - Search results for ERR6621
And it's pretty cheap if you buy it from the right suppliers. I try to keep one around, so if I use it I just add it to the next order.
Old Dec 29, 2011 | 01:37 AM
joking41's Avatar
I was carefull to take it off but when I did a lil oil was around each of the plenum holes so just get a new one? And when I went earlier to pull codes it said I was misfiring 8 4 2 3 7 and multiple cyclinders so I'm thinking intake leak? Correct me if I'm worng it was also pulling o2 sensor codes heater on 2 and 1 with no sighnal checking connections tomorrow and or testing/replace opinions much needed thanks
Old Dec 29, 2011 | 09:51 AM
I have reused both with no issues, trick is don't bend them and clean both the engine and seal surface before reinstalling.
Old Dec 29, 2011 | 12:43 PM
joking41's Avatar
Can I use a little gasket maker/rtv silicone? I usaully use it on paper/rubber gaskets I haven't been around metal gaskets usaul work on older cars.
Old Nov 11, 2012 | 08:05 PM
scarrell's Avatar
7th Gear
I'm in the same boat as Joking41. Do I use any sealer with the Plenum Gasket?
certguy12
Jan 30, 2013 10:42 AM
me 2
May 8, 2012 12:57 PM
Marcoadieter
Sep 26, 2010 10:26 PM
brw1982
Jul 21, 2008 11:42 AM
