Sponsored by: CARiD
Freeland 2002 upper air intake
Old Sep 25, 2010 | 11:00 AM
Marcoadieter's Avatar
Default Freeland 2002 upper air intake
I got the p1472 error code. also found the VIS motor technical bulletin
when i checked VIS motor 2 the the intake flap control arm does not move how it is supposed to.
do i need to replace the whole upper intake manifold or is there another way to fix?
Old Sep 25, 2010 | 11:29 AM
lordmorpheus's Avatar
I vaguely recall reading somewhere that the entire upper intake needs to be replaced for that symptom, but hopefully someone in the know can chime in.
Old Sep 25, 2010 | 02:27 PM
Rovin4life's Avatar
ignore the code, VIS motors so rarely cause problems its hilarious how many non lr shops put new motors in only to find out the misfires or other issues are causing the problems.
Get all the codes read. Not just those two.
you might find your bill is alot cheaper and alot quicker diag.
Old Sep 25, 2010 | 02:37 PM
Default Upper air intake
Yea i don't think its the VIS motor I just know that the arm did not move as supposed to according to Tech Buliten for VIS motor. the arm just moves where ever i put it. no spring acction to it.
Do I need to replace the Upper air intake?
Old Sep 25, 2010 | 03:16 PM
Rovin4life's Avatar
is it noisy. if not then don't bother but check all the codes. not just those.
Old Sep 26, 2010 | 10:26 PM
Default it makes a ticking noise
it makes a ticking noise, at least i think its coming from there.
pmchammond
Freelander
Jul 10, 2013 07:54 PM
BOSOX
Freelander
Jul 9, 2011 11:45 AM
jspettel
Freelander
Jan 11, 2009 06:06 PM
tommy36
Freelander
Nov 6, 2008 01:42 PM
jugador22
Apr 10, 2008 08:04 PM
