Used engine budget rebuild
Old Apr 11, 2021 | 05:35 PM
  #21
Fastercat's Avatar
Did you use assembly lube or oil on the bearings? is it totally frozen up or just hard to spin? Maybe plastiguage to check clearances? Did you have the crank polished?
Old Apr 11, 2021 | 05:48 PM
  #22
merebel's Avatar
Impossible to move seems like the caps marked with the 12 and 13 aka second and third from the front. And they do slide right down in.
Old Apr 11, 2021 | 05:54 PM
  #23
merebel's Avatar
Assembly lube and was harder to spin as I increased the torque when tightening
Old Apr 11, 2021 | 07:14 PM
  #24
Extinct's Avatar
Main caps are marked 2, 3, 4, etc. Post a pic of the assembly and we will see if we can help.
Old Apr 12, 2021 | 03:10 PM
  #25
merebel's Avatar
Ok here are the pics all of the numbers are on drivers side if looking right side up and in front of it
1st cap
Second cap
3rd cap
4th cap
Old Apr 12, 2021 | 04:27 PM
  #26
XRAD's Avatar
correct bearing thickness?
Old Apr 12, 2021 | 04:44 PM
  #27
merebel's Avatar
yes they are standard size
Old Apr 12, 2021 | 06:36 PM
  #28
merebel's Avatar
The bearing caps do the side bolts help align them in so they stay square ??
Old Apr 13, 2021 | 04:54 PM
  #29
merebel's Avatar
Any other thoughts on this? Everything is clean too so should be fitting flush I would think ?
Old Apr 13, 2021 | 08:32 PM
  #30
greisinb's Avatar
I’ve been following this thread because I’m about to start the reinstall of my crankshaft soon (block comes home from the machine shop tomorrow). Just out of curiosity, did you follow the crankshaft refit procedure in the rebuild manual? There’s a pretty specific torque sequence for the bolts and they aren’t all torqued to the same value. I’ll try and post a picture.
