Using the WIX Oil Filter
Old Aug 15, 2016 | 10:08 AM
matt3502's Avatar
Default Using the WIX Oil Filter
Over the years I have read on many occasions that a number of forum members use the the large WIX 51459 filter in order to raise the oil pressure. My D2 still has the plastic shield in place and I'm not in a position to remove it. My question is simple: Is there enough clearance between the the shield and the oil filter assembly to get the WIX in via the "access port" in the shield?
Old Aug 16, 2016 | 04:06 AM
NickAdams's Avatar
There was on mine.
Old Aug 16, 2016 | 06:40 PM
DiscoCam's Avatar
There is enough room. But you should take off the plastic thing. Just unscrew it, cut it into a few pieces and it will come off. It's only there to hide leaks anyway.
Old Aug 16, 2016 | 07:15 PM
matt3502's Avatar
I prefer to keep my oil leaks contained. That way my children will not have to see a grown man cry.
ljdiscovery
Jun 11, 2016 04:12 PM
jamescphillips
Mar 29, 2016 11:35 AM
pinkytoe69
Oct 4, 2013 10:13 AM
sayeedA
Nov 19, 2011 08:51 AM
lipadj46
Aug 20, 2009 02:16 PM
