..:: The Vaccum Situation ::..
Old Jan 8, 2017 | 09:16 AM
adolfojbonilla's Avatar
Default ..:: The Vaccum Situation ::..
Hello Roverers,
What should be the reason why after driving a while, and arriving at my destination, I hear the "vaccum" go on for a brief moment, then off again?
What should I need to look at to correct it, if it is a problem to correct ...I've noticed it being done a handful of times, I think.
Thank you all! ;-]#
Old Jan 8, 2017 | 09:49 AM
mollusc's Avatar
Do you mean the compressor for the air shocks?
Old Jan 8, 2017 | 10:02 AM
OffroadFrance's Avatar
Originally Posted by adolfojbonilla
Hello Roverers,
Thank you all! ;-]#
What you are more likely hearing is the rear air suspension compressor running. Due to the SLS the truck corrects the level when you stop and leave the truck and again when you use the remote to re-enter the truck. This is quite normal and not a problem, that's assuming you have rear air suspension and SLS.
Old Jan 8, 2017 | 10:40 AM
Best4x4's Avatar
It also helps if members fill out their signature with their vehicle specs. Makes diagnosis SO MUCH easier.
Old Jan 8, 2017 | 11:43 AM
LR03NJ's Avatar
True. Are models similarly equipped?
Old Jan 8, 2017 | 01:49 PM
I'm pretty sure my signature does have my truck's specs, in any case it is a 2002 Disco S2 SE ...and no, it is not the rear suspension, is the vaccum motor thay goes on every morning after you start the truck, but it goes on every now and then, as soon as I arrive at my destination.
Old Jan 8, 2017 | 01:51 PM
...nope, no air shocks on my truck.
Old Jan 8, 2017 | 01:52 PM
...nope, no rear air suspension on my truck.
Old Jan 8, 2017 | 01:53 PM
...hmmm, thought I had, but it is a 2002 Disco S2 SE
Old Jan 8, 2017 | 01:54 PM
...guess not.
