..:: The Vaccum Situation ::..
Old Jan 10, 2017 | 03:30 PM
  #31
Best4x4's Avatar
Originally Posted by adolfojbonilla
...thanks, I appreciate the feedback! ...although what I think you call the "main flex house" (the corrugated one that connects from the aluminum pipe to the pump) broke in a couple places when replacing the matrix hoses long time ago, so I had to "duct" tape it and still seems to hold... I guess is time to try and find a replacement. Other than that I don't see probs... just curious about the pump going on besides its morning ritual. Again, thanks!
I repaired that $$$ flex hose on the SAI D2 I had for just 10.00 total. 6.00 for some 3/4 heater hose, and 4.00 worth of good S/S hose clamps.
Take the special end by the pump and being careful (mine fell apart in my hand) tear it down until you have nothing but the actual connector and maybe 2-3 inches of the straight hard inner pipe with it. Then get your 3/4 heater hose, lube it up with some armorall, and slide it on. Then secure it with one of the new S/S hose clamps. Take it and measure it and cut it. Then if your aluminum shield is in good shape it can slide over the new hose to protect it (mine was trashed, but I got another one from a junk yard). Then secure that end to the hard metal line using the other S/S hose clamp. Boom 150.00 hose fixed for 10.00 with plenty left over for a spare!
Some people were like OMG that won't work , but sadly YES IT DOES! As long as your valves aren'y sticking causing exhaust gases up into the hose/pump. It will operate just like normal.
mmaesner
Jan 5, 2014 09:33 PM
Gromeo
Dec 27, 2013 11:57 AM
Beatrover20th
Jan 24, 2013 02:19 AM
01d2Jeff
Feb 1, 2012 08:04 PM
baddiscoII
Apr 3, 2010 10:16 PM
