Vacum hose not connected
None really. It's the hose providing vacuum to the SAI valve(s). Normally throws 1412 and 1415 IIRC, if it's off.
The rubber connector gets loose with age and can fall off in my experience. Might be worth going through the he vacuum system with new hose and rubber connectors. Doesn't cost much, if you have the time
This is your new truck? The check engine light is working, right?
Summitdog
01-19-2012 10:03 AM
