Vacum hose not connected
Old Feb 3, 2016 | 07:10 PM
LR03NJ's Avatar
Default Vacum hose not connected
I just found out that the hose was not connected for a while. I did not notice any difference after connecting it back. What will be the long term effect if that was not connected. Picture reference attached. Thanks
Old Feb 3, 2016 | 08:33 PM
number9's Avatar
Doubt any long term issues. May have had a SAI code?
Found same, pushed hose on/in nipple/boot and higher than normal idle RPM was miraculously closer to the manual specs. If worn or oil soaked a small cable tie(s) should help prevent it from coming loose in the near future.
Old Feb 3, 2016 | 10:48 PM
cappedup's Avatar
None really. It's the hose providing vacuum to the SAI valve(s). Normally throws 1412 and 1415 IIRC, if it's off.
The rubber connector gets loose with age and can fall off in my experience. Might be worth going through the he vacuum system with new hose and rubber connectors. Doesn't cost much, if you have the time
This is your new truck? The check engine light is working, right?
raygon
LR2
May 23, 2014 11:56 PM
charlotte007
Mar 22, 2011 12:56 PM
charlotte007
Mar 18, 2011 12:03 PM
JumPeR04
Jul 19, 2010 05:14 PM
