If it is not leaking....Its not a Rover<?>
Old Sep 14, 2014 | 08:59 PM
joejacintoaz's Avatar
Question If it is not leaking....Its not a Rover<?>
03 Disco SE7 with 139K
Recently changed head cover gasket and plenum and no oil leak for a week....so I thought.
So took it to a reputable shop and advised that my rear main seal is bad.
$1200 later its back on the road with a new rear main seal and gasket kit.
A week later - there is still oil leak coming from somewhere in between the engine and firewall near the coil packs. Took it back to the same shop and advised me that there is a valve behind my engine that needs replacing. Ask what valve it is and could not tell me so I pull it out the shop. WTF?
Oh - it did not stop there - BANK 2 Sensor 1 fault code came up after that so I changed both 02 sensor (pre cat). Drove it around for 20 miles with no code until the following morning. It is throwing misfire on cylinder 4.
Just bought two new coil packs and set of wires and plugs. I just don't see how to access the coil packs without removing the intake manifold.
Any ideas?
Old Sep 14, 2014 | 09:07 PM
jafir's Avatar
What about the crucifix seals? Part LUN000010
Old Sep 15, 2014 | 02:39 PM
sdhow's Avatar
Jafir is right. The rear main seals RARELY leak. If your leak is not coming from the center of the block, but rather at each side of the oil pan, it's your "crucifix" seals. If that's the case, I'd make that shop change those and eat the labor, because they SHOULD have changed those when they changed the rear main, even if replacing the rear main was in fact, unnecessary.
As for British cars leaking oil...in the UK, they don't pave roads, they "just scatter gravel across the oily discharge from the passing motors..."
Old Sep 15, 2014 | 02:49 PM
ZGPhoto's Avatar
My first thought as well, they LEAKKKKK
Old Sep 16, 2014 | 10:54 PM
Ok....I searched for the crucifix seal and foumd one illustration but did not really say where exactlyis the crusifix seal located. Cheers!
Old Sep 16, 2014 | 11:06 PM
jafir's Avatar
On the sides of the rear main bearing cap: http://robisonservice.blogspot.com/2...on-at.html?m=1
Attached Thumbnails If it is not leaking....Its not a Rover&lt;?&gt;-image-2365158890.jpg   If it is not leaking....Its not a Rover&lt;?&gt;-image-91481834.jpg
rally1
Feb 22, 2022 06:22 AM
jeffh
Jan 13, 2011 09:07 AM
kenjisnocon
Jun 16, 2009 06:28 PM
llPANCHOll
Feb 26, 2009 07:32 AM
rjennings
Aug 31, 2008 08:15 AM
