Valley Gasket
Old Mar 23, 2010 | 09:39 PM
ChanchoVerde's Avatar
Default Valley Gasket
Do I need anything else for a valley gasket job other than the valley gasket and 2 end seals? What are the valley gasket end clamps http://www.roverparts.com/Parts/ERR7282.cfm and do I need them?
I've got the valve cover gasket kit with new screws, the valley gasket and 2 end seals in my cart and ready for checkout. Any last minute suggestions?
Thanks for any and all feedback.
Old Mar 23, 2010 | 09:42 PM
tweakrover's Avatar
you reuse the clamps. I think you can get the whole gasket kit at auto zone cheaper than ab.
Old Mar 23, 2010 | 09:55 PM
Thanks for the feedback. I don't need the whole kit because I just finished replacing the upper IM gasket and t/body gasket last week. I just need the valley and valve cover gaskets.
Are rocker covers and valve covers the same thing? Found my answer: Yes they are!!.
Old Mar 23, 2010 | 11:23 PM
Done!! I hope they get this order here quicker than the last one.
Old Mar 24, 2010 | 03:26 PM
tweakrover's Avatar
by kit I meant vally pan, rubber end caps, and rtv silicon.
Old Mar 24, 2010 | 04:23 PM
V/C gaskets and new 8mm plug wires if you have not already replaced them.
Have you already up-graded the upper radiator hose to relocate the bleed screw to the black plastic tee, if not order a hose kit also.
Old Mar 24, 2010 | 05:53 PM
I have already replaced 8mm magnecor, bosch plugs, oem paper air filter, IM gasket, upper radiator w/ bleed screw at the tee, belt and thermostat.
I have ordered Valley gasket w/end seals, v/c gasket kit, MAF "O" ring, and the tensioner/idler pulley kit.
That just about covers everything. The beast should be back on the road this weekend.
FlyingZebra34
Apr 25, 2013 08:04 AM
jpmiller
Sep 26, 2012 06:32 AM
chad420
Oct 24, 2009 02:51 PM
JimScream
Jan 6, 2009 02:01 PM
roverwoody
Sep 13, 2008 03:12 PM
