Valley pan gasket (lower intake gasket) round 2
You might want to try reading the packaging before you start leading people down the wrong road, Quote from Locktites website
Loctite® Threadlocker Red 271™ is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
Oh yah; I forgot good luck getting that intake off, did you think to use it on your head bolts while you were there.
