value of my disco
Old Aug 14, 2018 | 03:43 PM
  #21
jamestfl's Avatar
Originally Posted by Extinct
Any coolant in the oil or just the cylinders? coolant in the oil is usually a blown front cover gasket (cracked cylinders are very rare) and coolant in the cylinders is just a blown head gasket (stock ones do not last forever).
x2. If it's just coolant in the cylinders, that just tells us it's most likely a headgasket. Depending on the amount of damage, they may need to be machined. When I did mine, did not get heads machined, just slapped a new gasket in there and it did the trick. Doing a headgasket replacement is little more than a step by step process of removing bolts, screws and parts, cleaning everything, then putting it all back. Its totally doable.
Old Aug 14, 2018 | 04:23 PM
  #22
Big Jim Swade's Avatar
A disco 2 is one of the few vehicles where you can put a new engine it for $5,000 and the whole vehicle is worth $4,500 when you are finished installing it :-)
Old Aug 14, 2018 | 05:33 PM
  #23
Sixpack577's Avatar
Ha! Lmao!
sad but true
Old Aug 14, 2018 | 06:36 PM
  #24
shanechevelle's Avatar
What state are you in?
you also have an early year D2. The engines aren't that bad in these, the 04's are the worst. Good chance you put some fresh head gaskets in there and it would be fine.
Old Aug 14, 2018 | 07:19 PM
  #25
redwhitekat's Avatar
i dont think so if the truck is in good shape clean exterior and interior you can get up to 10 k or more
I just turned down 9 k for mine
Old Aug 14, 2018 | 08:21 PM
  #26
The Deputy's Avatar
^^^^Yeah, but that's like 12 dollars US funds...lol.
​​​​​​​Sorry, couldn't resist.
Old Aug 15, 2018 | 08:15 AM
  #27
jamestfl's Avatar
Couple of off topic qs abt your rig- what cross bars are you using, and what kind of roof treatment did you do?
Old Aug 15, 2018 | 04:28 PM
  #28
water rover's Avatar
Thule Crossbars which I use as surf racks. As for the roof treatment, it might warrant a new thread but here are a few pics of before and after.
Before shot. I sanded it down with a fine grit first.
taped the truck off all the way around and used this with a spray gun
work in progress Finished look in just a few hours.
closeup of the roof which I did a few years ago and still looks the same now.
Old Aug 15, 2018 | 06:37 PM
  #29
jamestfl's Avatar
Thanks for that. Looks great. And lasts!
Old Aug 16, 2018 | 08:42 PM
  #30
Extinct's Avatar
Should have done it in Safari white! Makes the truck cooler in the hot sun.
