Valve spring compressor recommendation?
Does anyone have a recommendation for a reasonably priced valve spring compressor for the D2. I’ve been looking around for a bit but can’t land on one.
@greisinb That one would be tough to use on tight multiple valve heads. Most removers work ok on our valves as there is lots of space
F*** these things. They do work, but they're a pain in the butt and they're sketchy as heck.
The best thing I've used is an 8" C clamp from harbor freight with the foot ground out to go around the retainer locks.
I also like to take a cheap 5/8 socket and weld to the end of the screw so I can just run it down with a drill or am impact instead of cranking it by hand. Here's some pictures of mine.
