Valves Stem Seals
Old Oct 3, 2017 | 06:43 AM
Mustafa Telawi's Avatar
8th Gear
Originally Posted by Fast951
Pressurize each cylinder and use this tool to compress the springs. Not an assumption at all, I've done this and it works great for situations where you don't care to remove the head(s).
I have it, and yes it work on other cars. Did you try it on the 03 Land Rover Discovery, the SAI Valves need to be removed, which cause the air escape.
Old Oct 3, 2017 | 09:51 AM
Fast951's Avatar
Yes, I have used it on a Discovery and did not have a problem with air escaping from SAI that I can remember. But as you say, you can just plug the holes in the head to resolve your issue. The tool works well but is a little tricky when compressing springs on the rear of the heads close to the firewall. On the left side the heater core pipes are also in the way, but you can work around them if you take your time.
vdub911
Sep 12, 2014 12:45 AM
abran
Jan 3, 2014 11:09 AM
ruffram
Sep 1, 2011 08:15 PM
Choppee
Dec 10, 2006 07:33 PM
Choppee
Dec 9, 2006 10:43 PM
