Vehicle do not move
Old Sep 18, 2021 | 01:50 AM
suntreemcanic's Avatar
Put the front driveshaft in this evening. The rig now moves, the transmission shifts and the brakes work good.
Old Sep 19, 2021 | 10:41 AM
H Hill's Avatar
Check out the Ashcroft CDL shift linkage. I installed it on my 2000 Disco 2 and really like it. No need to change out the SLABS unit.
Linkage is all mechanical.
Old Sep 19, 2021 | 07:30 PM
mollusc's Avatar
Updating the SLABS unit is highly recommended if you add a CDL lever. The early SLABS programming does not recognise the combination of an activated central lock and traction control. The brake mapping is also slightly different in the later unit.
Old Sep 20, 2021 | 09:41 AM
H Hill's Avatar
Mollusc,
Is the '03/04 SLABS unit that you recommended for the '00 with a CDL lever a simple "plug and play" switch with the stock '00 unit?
Old Sep 20, 2021 | 11:16 AM
mollusc's Avatar
Yes, although there may be options enabled in the new unit that do not apply to your vehicle. You may get one that is set up for air shocks but your truck has coils, for example. These settings can all be changed using a Nanocom, Hawkeye, etc.
Jose Montoya
Jan 13, 2021 11:06 AM
hrhoward
Aug 24, 2016 11:15 AM
lr2001silver
Aug 22, 2012 12:25 PM
hatanhi
Jul 23, 2012 06:46 AM
GandAautoLLC
Aug 25, 2011 07:49 PM
