Vehicle do not move
Updating the SLABS unit is highly recommended if you add a CDL lever. The early SLABS programming does not recognise the combination of an activated central lock and traction control. The brake mapping is also slightly different in the later unit.
Yes, although there may be options enabled in the new unit that do not apply to your vehicle. You may get one that is set up for air shocks but your truck has coils, for example. These settings can all be changed using a Nanocom, Hawkeye, etc.
