Verdict on anti-freeze?
Old Sep 20, 2013 | 04:01 PM
gbob's Avatar
Default Verdict on anti-freeze?
So what's the consensus here on the forum for anti-freeze? Dexcool is out, right? What about water wetter?
Going to install new t-stat (190) and wanna make sure I've got the right stuff to but back into my '03 disco.
FYI, not sure if it matters but I live in "Bahston," and never off-road my disco. Just look-cool-soccer-dad.
Thanks,
Rob
Old Sep 20, 2013 | 04:04 PM
jafir's Avatar
Dexcool doesn't like leaks, I guess. D2 likes to leak. My LR3 still has dexcool in it after over 180,000 miles. (probably not the original fill, I hope)
Water water is good.
Old Sep 20, 2013 | 04:07 PM
dusty1's Avatar
180 t stat is the popular recommendation. water wetter is fine, some claim that it makes a difference. i did not see one. also some stick to dexcool, but there are alot of dexmud photos out there.so, I opt to go with the popular consensus = green stuff 50/50. prestone for me.
Old Sep 20, 2013 | 04:52 PM
blackhills's Avatar
Ditto 50/50 green and flush often
Old Sep 20, 2013 | 05:36 PM
primussucks's Avatar
i use green 50/50. water wetter, but mine leaks so much it is probably all out by now.
i think the consensus is.. what ever you use.. change it more then once in the trucks lifetime.
Old Sep 20, 2013 | 06:14 PM
Big Jim Swade's Avatar
Mine had Dexcool in it when I bought it 2 years ago. I did a thermostat change and coolant flush last summer and I put Prestone Decool back in. So far no problems.
Old Sep 20, 2013 | 09:01 PM
With the wide range heat gauge, you won't know when Dexmud has built up unless you check radiator top to bottom with an IR thermometer, should be within 10F. Owner manual says change coolant 2 years or 30,000 miles, no one reads those things.
I like green 50/50.
Old Sep 20, 2013 | 09:09 PM
acamato's Avatar
I am about to flush mine and put in Peak Global anti-freeze. I finally found a source for it.
Old Sep 20, 2013 | 09:10 PM
jafir's Avatar
Only place I see it is the gas station in front of Walmart.
I haven't bothered to read up on it. Is it OAT?
Old Sep 20, 2013 | 09:47 PM
dr. mordo's Avatar
The way I look at it is one type of antifreeze might clog up the system when exposed to air. The other type won't.
So I don't see why anyone would consider running dexcool when there's a zero risk alternative.
