And the vibration was!!!!
Old Oct 26, 2012 | 03:53 PM
Spencerfitch's Avatar
Default And the vibration was!!!!
In the transfer case!! I had no slip or slack. Just got truck back from the shop they swapped in my used transfercase and wham! Never rode so good' now on to lift wheels paint blah blah
Glad I did my little abs tc fuse pull trick to sort front from back vibration
Old Oct 26, 2012 | 08:39 PM
Jared9220's Avatar
Could you explain this "Trick"
Old Oct 26, 2012 | 09:08 PM
In previous threads I made you can find details.
Because 03s have no CDL (mine does now) I couldn't just pull a drive shaft and drive to de if it was front or back drive related.
Basically, I pulled the abs and tc fuse so that truck wouldn't think a wheel was slipping and send me flying off jack stand. I lifted the front two (and tried one at a time to Narrow it down) wheels off the ground applied parking brake and chocked rear wheels. Then I put it in drive and got it up to vibration speed and yes it was still there. Then I lifted the back and chocked the front VERY VERY VERY VERY GOOD. Released hand brake and accelerated. No vibration.
Old Oct 26, 2012 | 09:35 PM
04duxlr's Avatar
Then I lifted the back and chocked the front VERY VERY VERY VERY GOOD. Released hand brake and accelerated. No vibration.[/QUOTE]
I'm glad to hear that worked for you. Not to be a dick but if it had dropped off the jackstands that would have been AWESOME! Kind of like the ending of Ferris Bueller's Day Off only forwards instead of backwards.
notaguru2
Feb 22, 2009 05:33 PM
BayouDisco
Nov 8, 2008 12:21 PM
redhawk
Sep 20, 2008 02:53 PM
mr.47
Mar 27, 2007 02:45 PM
aBs0lut30
Jul 5, 2006 10:43 PM
