Vibration
Old Oct 15, 2013 | 07:51 PM
REVS's Avatar
Default Vibration
Looking for some advice. I have 2001 d2 with 107000 miles. The truck vibrates. I have replaced the driveshaft with new and still have the vibration. I also rebalanced the new shaft but it still vibrates. The truck doesn't vibrate with the shaft removed and cdl locked. I also can hear a slight chirping noise. Could this be the front output bearing? There is some play there with the shaft removed?
Old Oct 15, 2013 | 08:36 PM
new as in oem style shaft or upgraded so you can grease it every oil change? Sure sounds like a problem shaft.
Old Oct 16, 2013 | 08:56 PM
REVS's Avatar
The shaft is new with grease fittings. This is the second new shaft shaft that I tried. I had the balance checked at a local shop. I believe I could hear some noise with shaft removed at highway speeds?
Old Oct 16, 2013 | 09:05 PM
ZGPhoto's Avatar
ahha... I'm going through the same thing right now... What speeds does your truck vibrate with the shaft installed?
Old Oct 16, 2013 | 09:58 PM
REVS's Avatar
Vibrates 35 mph and up. If I pull the front shaft it's nice and smooth.
Old Oct 16, 2013 | 10:38 PM
ZGPhoto's Avatar
For me it's 60 and up. I have tried different front shafts, it's not the shaft.
Kiwi Mike
Mar 2, 2006 07:32 AM
kennims
Jan 22, 2005 08:22 AM
Greyfoxvt
Jan 9, 2005 09:04 AM
berg7171
Dec 27, 2004 06:35 PM
Benhamtroll
Dec 13, 2004 04:35 PM
