vibration at 65
Old May 19, 2011 | 07:23 PM
northridgeconstruction's Avatar
4th Gear
Default vibration at 65
my front shaft went out so i marked the position and removed it, took it to a good drive shaft shop, they rebuilt it and told me i did not need install to previous marks because they balanced the shaft. the problem i have now is at 65 to 75 only when i am accelerating there is a vibration. it only happens between those speeds and only during accelerating. any help would be appreciated
also can i run the vehicle with the front shaft removed
Old May 19, 2011 | 07:36 PM
DarylJ's Avatar
Search. This has been covered to death. With multiple outcomes/solutions.
Not unless you have a CDL, and even then I wouldn't suggest it for long.
Old May 23, 2011 | 02:49 PM
brigadier_dj's Avatar
i had a new shaft built by GBR in utah a month or so ago. i installed without lining up also and have a vib 70-75 and again at 85-90. best guess i heard was potentially a bad ujoint but i think the whole drive line needs to be rebalanced.
not really helpful but i'm in the same boat. GBR is going to take a look at the shaft and stand behind their work so i appreciate that.
Old May 23, 2011 | 05:51 PM
sloan74's Avatar
u drive your rigs @ 90 mph?
Old May 24, 2011 | 07:43 AM
jeffh's Avatar
x40 on this one... yes you should certainly find the issue causing the vibration but at the same time I would suggest that you drive a tad slower. these are really heavy vehicles that are not intended to be driven at those kinds of speeds. Not to mention I do not know many places in the US where that speed is legal oh and can you imagine a more direct way of taking your all ready low gas mileage and dropping even lower.. C'mon guys be smart and be safe.
Old May 24, 2011 | 09:05 AM
absolutely! i like to see how hard she'll go before she explodes.
no i noticed the vibration and one time i went that high to verify that it was a harmonic resonance issue.
and thank you. i'll drive responsibly.
Kiwi Mike
Mar 2, 2006 07:32 AM
kennims
Jan 22, 2005 08:22 AM
Greyfoxvt
Jan 9, 2005 09:04 AM
berg7171
Dec 27, 2004 06:35 PM
Benhamtroll
Dec 13, 2004 04:35 PM
