Vibration, I cant find it. Help me please.
Old May 16, 2014 | 09:54 PM
  #31
Dane!'s Avatar
If you haven't change any motor/trans mounts that could be a reason, especially if you said it was a small vibration. Since your running with only the rear, have you checked the rear rubber coupling?
Old May 16, 2014 | 10:03 PM
  #32
REVS's Avatar
There's only a very small vibration when the front shaft is out. Rear rubber coupling looks ok. My rover guy thinks transmission output shaft, I'm not so sure.
Old May 17, 2014 | 01:26 AM
  #33
Dane!'s Avatar
It could very well be, but if you have such a minor vibration, I would think its the trans/motor mounts. Imagine how fast the drivetrain is spinning at 30mph. Its worth a try since they are only 25$ a piece I think, and is much easier than pulling the t-case to just check the shaft, when you'll actually have to pull them anyways!
nick_m3
Nov 7, 2014 08:38 AM
joking41
Jan 19, 2012 07:00 PM
camgkh
May 21, 2010 08:24 PM
RealityTheDon
May 18, 2010 05:06 PM
Classklown90
Oct 27, 2009 04:26 PM
