Vibration in my Disco 2
Old Nov 24, 2023 | 08:22 AM
ReignRock's Avatar
Default Vibration in my Disco 2
I have a vibration coming from somewhere and I can’t pinpoint it. At about 30 mph it starts and doesn’t really go away but it does lessen a bit. It did it when I first purchased it and an alignment was the first thing I did with it. I also put on some brand new tires. I don’t feel it in my steering wheel. When I took it in to the mechanic (Austin Rover Works in Round Rock, TX) for a head gasket job, I asked them to also look at this issue. They said it was most likely from the lift and tires. It has maybe a 2” lift and some Toyo M/T Open County 275/55R20. I have these same tires but in 33’s on my F250 and it was never noticeable. The tires that were on the disco previously were of the same size but different brand but not as aggressive and it still had the vibration. Mechanic also said the drive shafts were in good shape as I asked them to check those as well. What else could cause any vibration? Should I get a second opinion at another mechanic? My closest option would be Hill Country British in San Antonio.
Old Nov 24, 2023 | 12:31 PM
andino's Avatar
Did the vibration start after new tires? If so, that's where I'd start to ensure the balance is correct. Sometimes balancers are off for whatever reason and need a second go. If you haven't greased your prop in awhille, I'd take the shafts off to inspect rather than just a visual look and feel.
Old Nov 24, 2023 | 01:36 PM
Harvlr's Avatar
Also maybe it’s time to replace the rubber doughnut at the aft end of the rear drive shaft.
Old Nov 24, 2023 | 02:00 PM
ReignRock's Avatar
No it was doing it before the new tires. And I did bring a grease gun home from work for that purpose but it ended up not working. Figures. But I’ll get that done for sure.
Old Nov 24, 2023 | 02:01 PM
ReignRock's Avatar
I’ll get that checked out, thanks!
Old Nov 26, 2023 | 02:27 AM
greisinb's Avatar
Is the vibration felt in the steering wheel or in your seat? If it’s through the steering wheel it’s most likely through the front wheels or your front drive shaft is about to let go (ask me how I know). If your feeling it through your seat it’s most likely from the rear running gear.
Discorama
Aug 10, 2024 10:14 PM
me6067
Apr 16, 2016 02:01 AM
rrhyne
Jan 29, 2009 07:46 PM
dharch
Aug 28, 2008 07:58 PM
LiftedRover96
Feb 7, 2006 10:41 PM
