Vibration and Noise - Drive Shaft?
I have some vibration in the front end. It does it at all speeds. It also seems like their is a ticking noise under the front end. Sounds like that is where it is coming from anyway. It just started doing this out of the blue. I crawled underneath and looked around and I didn't see anything broken or loose. I did notice that their is a grease nipple on the front u-joint. Any advice on what I should do? Should I shoot some grease in there and see if that helps? Can't seem to find a Land Rover mechanic here in Fargo, ND. Would a normal mechanic that works on drive shafts be able to do it if I brought them the drive shaft and parts. Any help is appreciated.
Fantastic...now check for grease nipples on each u-joint (2) in the double cardon (#1 in pic)...if not, STOP DRIVING and re-build drive shaft with greaseable parts immediately.
See the "Write ups" and "How To" section above for this:
Drivetrain
- Propshaft Rebuild - Land Rover Forums - Land Rover Enthusiast Forum
- https://landroverforums.com/forum/di...ld-done-30781/
**DII Front driveshaft rebuild Part #'s U-joints are Precision 344 (3 required) and Centering ball is Precision 617 (1 required)**
Drivetrain
DiscoJon
07-14-2019 01:51 PM
Snafu / Disco Fries
03-24-2011 08:16 PM
