Vibration and Noise - Drive Shaft?
Old Apr 19, 2011 | 06:25 PM
Rover Nick's Avatar
Default Vibration and Noise - Drive Shaft?
I have some vibration in the front end. It does it at all speeds. It also seems like their is a ticking noise under the front end. Sounds like that is where it is coming from anyway. It just started doing this out of the blue. I crawled underneath and looked around and I didn't see anything broken or loose. I did notice that their is a grease nipple on the front u-joint. Any advice on what I should do? Should I shoot some grease in there and see if that helps? Can't seem to find a Land Rover mechanic here in Fargo, ND. Would a normal mechanic that works on drive shafts be able to do it if I brought them the drive shaft and parts. Any help is appreciated.
Old Apr 19, 2011 | 06:47 PM
Snafu / Disco Fries's Avatar
Yes, any mechanic/trans shop/drive line shop should be able to do that for you. I would be cautious for sure driving it though. When you say you see the greasable nipple, do you see them on both sides of the front drive shaft? If so, it has already been rebuilt. Regardless, take a good look at it and consider towing it to a good shop. Should only be a couple hundred bucks.
Old Apr 19, 2011 | 06:56 PM
Rover Nick's Avatar
Thanks for the response. It is basically like this picture.
Old Apr 19, 2011 | 08:16 PM
mwindth's Avatar
Fantastic...now check for grease nipples on each u-joint (2) in the double cardon (#1 in pic)...if not, STOP DRIVING and re-build drive shaft with greaseable parts immediately.
See the "Write ups" and "How To" section above for this:
Drivetrain
- Propshaft Rebuild - Land Rover Forums - Land Rover Enthusiast Forum
- https://landroverforums.com/forum/di...ld-done-30781/
**DII Front driveshaft rebuild Part #'s U-joints are Precision 344 (3 required) and Centering ball is Precision 617 (1 required)**
DiscoJon
Jul 14, 2019 01:51 PM
glassman66
Feb 12, 2012 10:21 AM
Snafu / Disco Fries
Mar 24, 2011 08:16 PM
andrewmcoffin
Nov 21, 2010 08:18 PM
brooksa
Jun 6, 2008 09:34 PM
