Vibration Problem
Old Nov 17, 2016 | 07:51 AM
zuke's Avatar
Default Vibration Problem
Have had a small vibration at speeds of 60 mph. I put on new tires and had an alignment done but it is still there.
Could this be an imbalance in a driveshaft?
Old Nov 17, 2016 | 08:30 AM
Red5's Avatar
Could be, yes. Was it there before the new tires and alignment?
Old Nov 17, 2016 | 08:57 AM
zuke's Avatar
Yep It seems less though and the alignment shop said it was way out of whack. The vibration is not in the steering wheel. The passenger seat just wiggles a little.
Old Nov 17, 2016 | 10:57 AM
Red5's Avatar
Has the original front prop shaft been replaced or rebuilt? If not, do that asap. Like before you drive it anymore.
Also check the the u-joint on the rear and inspect the rotoflex coupling at the rear diff.
Old Nov 17, 2016 | 11:16 AM
The Deputy's Avatar
Old rule of thumb...
If you feel it in the steering wheel...usually an issue in the front end components.
If you feel it in your seat...it's usually in the drivetrain.
Since you feel more of it in your seat, I'd check the rear shaft and joints.
Side note:
My wife complained about a vibration in the front of our 03, so I went to take it to work to check it out...never got that far. Vibration was to worrisome (pictured having to replace "another" trans), so turned for home. Jacked it up and all I could find was the weight missing on the front driveshaft (which was about two 2" by 2" in size). Haven't had a chance to remove or have balanced yet...but everything else seemed okay. Hopefully within a week or so I get that done.
Brian.
Old Nov 17, 2016 | 11:38 AM
OffroadFrance's Avatar
Hi, could be wheel balance if in the steering or shaft balance or UJ's knacked. Alternatively engine and autobox mounts create vibes. Also check the steering rod ends for play as they can create weird vibes at some speeds.
Trevorn
LR4
Nov 18, 2020 05:59 PM
FlyingZebra34
Jul 20, 2012 11:37 AM
bothomasmusic
Jun 17, 2011 11:52 AM
