viscous fan
Old May 4, 2012 | 01:42 PM
jeffh's Avatar
Default viscous fan
Sooo, I have the original fan on my '03, she has 115k on her. I have a fan from an '02 with a brand new viscous clutch. The question is... is the difference between the 99-02 fan and the 03-04 fan enough to make switching out for the 02 with the new clutch a bad idea. in the end I am just trying to save a few hundred dollars. but do not wish to do that at the cost of the engine not getting the proper air flow. I have no cooling issues, all runs well. but a new clutch is certainly better than one with 115k on it..
as always thanks for the reply's
Old May 4, 2012 | 02:18 PM
When you look at the fan, is the pitch of the blades (depth) greater? If so, and same quantity of blades, and same diameter, the steeper pitch will move a little more air. This is only an issue at idle of very slow traffice. At highway speed the air flow is much greater than the fan. Just try holding a large pizza box out the window at 65 mph...
IMHO if it was a great difference, you would see a lot of guys with the smaller one changing out to the larger one, given our heating issues. I think the 03 - 04 fan looks very similar to a D1 fan as well. I replaced mine with a really deep one from a Chevy Blazer.
jafir
Feb 10, 2017 11:08 AM
Jawbox
Jun 4, 2012 04:52 PM
apcollin
Mar 27, 2008 09:22 PM
btp226
Engine & Internal
Oct 21, 2007 08:37 PM
okdiscoguy
Sep 19, 2007 12:15 PM
