Viscous Fan
Old Mar 18, 2014 | 04:01 PM
Reza's Avatar
Default Viscous Fan
Recently, I had to take off the Viscous fan to repair a coolant leak. After I put it back on, I notice that the fan runs even on start up. Is it supposed to?
Thanks
Reza
Old Mar 18, 2014 | 04:21 PM
dusty1's Avatar
usually runs loud and hard on start up till the fluid is unsettled, then it quietes and does its thing
Old Mar 18, 2014 | 10:00 PM
jfall's Avatar
Concur with Dusty.
Running loud on startup means you have a GOOD fan.
A bad fan will not do that.
Old Mar 19, 2014 | 03:40 AM
Unless it continues to be loud, which means your fan is no longer viscous coupled, it has failed and stuck. When coud, spin and release fan, should not spin but 1/2 to 1/4 turn. Do again when warmed up, should still feel like peanut butter inside, and not spin more than 1 revolution when released. Freewheeling means clutch is toast, fluid is with Elvis. Now the electric fan on radiator should always spin freely. And should operate at the temps and conditions stated in the RAVE shop manual specifications pages. The D1 electric fans fun whenever AC is on, the D2 has different program and wiring.
Old Mar 19, 2014 | 11:07 AM
schwaggy's Avatar
Is an aftermarket clutch ok for this?
On sale for $80 at BPU instead of $295 for LR.
Old Mar 19, 2014 | 12:03 PM
drowssap's Avatar
what year? 03-04 are one piece clutch and fan.
if it is 99-02 that fan will work there is also a chevy fan you can get locally that works for $40.00. you just have to open up the 4 holes.
Old Mar 19, 2014 | 01:11 PM
schwaggy's Avatar
'03 - Good Point. And DAMN. That's $385
I guess it's a good idea if I'm doing the rest of the system - radiator, pump, hoses, etc...
Old Mar 19, 2014 | 01:34 PM
jamestfl's Avatar
dang, I just put a Hayden Severe Duty into my '00, and that was maybe $80 (Amazon). maybe shop around a bit.
Old Mar 20, 2014 | 07:01 AM
drowssap's Avatar
you can update by used a 99-02 fan and clutch
jafir
Feb 10, 2017 11:08 AM
Jawbox
Jun 4, 2012 04:52 PM
apcollin
Mar 27, 2008 09:22 PM
btp226
Engine & Internal
Oct 21, 2007 08:37 PM
okdiscoguy
Sep 19, 2007 12:15 PM
