viscous fan stuck
I have had to pull up on the belt while doing this, there are also strap wrenches that can be used to cinch down the a pulley and restrict the belt, or a c clamp on the pulley with a rag to prevent gouges to the pulley. Without the belt on, it will be mucho more difficult.
Ok, I'm done for the day. You veterans probably know this, but I had to find out for my self. The RAVE is entirely wrong in that it is NOT necessary to remove the fan to replace the drive belt. I did not attempt replacement without removing the fan earlier because I had wanted to get a better look at the front of the engine and knew I'd have to remove it if I ever tackle what I think was a front seal leak. However, White Shepherd has stopped the leak at least for now. When the nut still would not budge this morning, all I could think about was shearing a bolt off using Snafu's method and I did not want to go there. So the fan stays for another day - new belt is in place.
It gets better. While under the truck fishing the belt around the lower pulley, I checked out my drive shaft. Yep, zirc fittings The whole thing looks brand new!!!
Well then were's the grease gun? One style many like is the synthetic "green" grease, it is more water proof, used on farm gear because it is also resistant to fertilizer, etc. Availabeleat most auto parts chains, and farm stores like Tractor Supply.
BTW, where in the RAVE is the error you mention?
Now I'm on to finishing the Suzuki project so I can put it up for sale
