visible smoke from muffler
Old Jan 31, 2009 | 07:00 PM
Aj6543's Avatar
Default visible smoke from muffler
my 2000 disco is putting out visible smoke while i am driving. is this normal? i took it to the emissions and it passed luckily. but on the requirements, it said that smoke could not be visible for more than 10 seconds. should i be worried?
I want to add, that white smoke is no longer coming out. Does white smoke come out when it is really cold?
Old Jan 31, 2009 | 07:18 PM
Default RE: visible smoke from muffler
Yes, be worried.
Check your coolant level, you most likely have a blown head gasket.
Old Jan 31, 2009 | 07:25 PM
discodefender's Avatar
the theme of the day?
Check your oil and look for moisture
Old Jan 31, 2009 | 07:30 PM
ORIGINAL: discodefender
This is the theme for DII's. Head gaskets are like timing belts, you WILL be replacing them.
Old Jan 31, 2009 | 07:32 PM
Sounds like your truck is getting ready for some head gaskets.
Go to your mechanic next week and don't drive it much in the mean time to prevent any additional damage.
Old Jan 31, 2009 | 07:34 PM
I'm with you. I'm **** about keeping up with things. I probably have the only defender without a leak that looks as good underneath as up top. Head gaskets are not that big of a deal. Actually gets me out of the house and up to the shop to drink beer with my friends for a day.
Old Feb 1, 2009 | 01:00 AM
Willie 00D2's Avatar
What color is the smoke?
Willie
Old Feb 1, 2009 | 06:42 AM
unimoged's Avatar
It will help if you can tell us the following:
[ul][*]Mileage on the engine.[*]How much coolant are you adding every week.[*]Is it running hot or did it overheat lately.[*]Is it emitting water vapor on startup when cold or is it doing it all the time.[/ul]
Old Feb 2, 2009 | 07:29 PM
Aj6543's Avatar
Old Feb 2, 2009 | 07:35 PM
Yah white smoke will come out when its really cold from any car. I would say it's steam not smoke.
Willie
JKK
Headers, Intake, & Exhaust
13
Sep 17, 2014 01:22 AM
Hyakku
Aug 19, 2011 04:12 PM
wease206
Jan 8, 2008 02:02 AM
christians1600
Jan 2, 2008 02:05 PM
wease206
Dec 26, 2007 03:44 AM
