Wanting to remove SAI
Old Feb 22, 2016 | 01:04 PM
ewbourne's Avatar
Default Wanting to remove SAI
I have the dreaded p1412 code and have read all the write ups on how to fix it and have decided to just remove it. Is there a bad/good reason to remove or not remove. I am looking for the post that can walk me through the procedure if thats the path I go.
Old Feb 22, 2016 | 01:09 PM
jamieb's Avatar
I can't really elaborate, but I've read from Range Rover owners it was a matter of disconnecting the SAI pipe, turn off the SAI pump, plug the sensor holes and then just deal with the service engine light that won't go off after that.
I would be interested to hear more details myself, just to have the knowledge.I understand it is not a required system, other than to pass emission tests and pollute less.
Old Feb 22, 2016 | 01:33 PM
number9's Avatar
Have you checked your SAI vacuum pipes & nipples for security/deterioration. A couple mine had slipped off, reattached and stopped getting codes. Eventually secured nipples better with miniature cable ties because of falling off when bumped when doing other mx.
That's what I've read also. You'd probable want to have a permanent scanner installed for easier repeated clearing of codes/light. Using a non-SAI ECM supposed to be another option?
Good luck with whatever route you go down.
Old Feb 22, 2016 | 01:41 PM
matt3502's Avatar
I have the same thing going on myself. I cracked one of the vacuum lines installing new 02 sensor and basically rebuilt the lines with new tubing. It has not helped. I read in an old posting about taking out the SAI valve and cleaning as it might be stuck. I'm going to go to HFT and buy a vacuum tester. After that my next stop is a used SAI valve. Not dropping big bucks for a new one.
Old Feb 22, 2016 | 02:10 PM
ewbourne's Avatar
I was driving it home when it just down shut down so I scanned it and the code appeared. I tried to restart and it would not. After about 20-30 minutes I was able to get it running with it to only shut off a few miles down the road. I had to have it towed home. I have replaced the crank sensor less than 1000 miles ago
Old Feb 22, 2016 | 02:32 PM
number9's Avatar
SAI code should be unrelated to your current shutting down problem far as I know. You might want to start a thread about the symptom/problem to get more attention/help with that.
Old Feb 22, 2016 | 04:08 PM
Alex_M's Avatar
I removed mine a couple months ago.
All that it took was removing the pump/hoses/vacuum lines and plugging the vacuum ports on the intake. I also had to take the plugs in the head and I welded up the ends. I actually welded a couple of them still in the engine because I couldn't get them out.
I do have a constant check engine light, but other than that no problem. It's important to note that if you have emissions testing, you will not pass with it removed. You will also never be able to sell it to someone who has to go through emissions testing and you will never be able to move somewhere with it that has emissions testing.
As for your current issue, that's not caused by the SAI. If you've got a new CKP, then I'd check your fuel pump. That's the only other thing I can think of that would be able to cool down, start again, and then quit again when it heated back up. It could also be your new CKP though, I'd replace it under warranty and see if that fixes your issue.
Old Feb 22, 2016 | 05:17 PM
Joemamma1954's Avatar
Someone on here a while back was saying the CKP would stop when heated and the fuel pump would just stop. Not saying which is right, I have not had either problem.
As for the SAI, I would check all vacuum lines, especially the rubber L that goes into the vacuum canister on the left side. They carry them at most auto supply houses. The other problem I had was the hose that goes from the SAI pump to the metal pipes had a slit in it and I wrapped it with that metal silver ducting tape, the A/C guys use. Then made sure all the rubber to metal hoses had clamps on them and the code and light went away. I also had a vacuum leak where the hose goes from the intake to the vacuum canister at the intake manifold, and sealed it with ATV. The SAI is pretty straight forward. The pump normally will come on only at cold start and stay on for maybe a minute or so.
Old Feb 22, 2016 | 05:23 PM
ewbourne's Avatar
I am going to trace all the hoses down and see what I can find.
Thanks for the replies
gatorm
Aug 11, 2017 04:04 AM
FyrRover
Feb 8, 2016 05:18 AM
roverbob
Sep 2, 2012 08:34 PM
uh60driver
Apr 2, 2012 11:22 PM
Bryan H
Jul 23, 2010 02:39 PM
