Warped valve cover
Old Jul 24, 2008 | 06:05 PM
Default RE: Warped valve cover
How do valve covers leak coolant? There is no coolant there.
Old Jul 24, 2008 | 06:22 PM
jdelp's Avatar
Thank you! All I can figure is possibly throttle body leaking onto the valve covers, otherwise it doesn't make sense. Your valve covers will leak oil, not coolant.
[align=left] [/align]
Old Jul 24, 2008 | 07:03 PM
A v/c gasket can not leak coolant or cause an over heat.
Never turn off your overheating engine, that is the best way to ruin it. Let it idle with the hood don and the heater on the higest fan speed and the hottest heat setting till iy cools down.
I would suggest you have a mechanic regarding this before you act.
Old Jul 24, 2008 | 08:00 PM
PalmettoDisco's Avatar
Mike, it apparently overheated WHILE AT IDLE. I doubt the heater would draw enough heat out to be sufficiently effective, while already at idle and the temp gauge pegged.
Jason428sc
Mar 11, 2013 07:57 PM
jallen
Engine & Internal
Nov 5, 2012 08:30 AM
KENW
Aug 9, 2011 08:36 PM
cleopard
Oct 20, 2009 08:50 AM
majrmike
Oct 9, 2007 03:13 PM
